Cruise control problem
Old Oct 1, 2008 | 03:23 PM
soxfan's Avatar
5th Gear
Default Cruise control problem
My cruise control has not worked since I bought my Disco a couple years ago. I seldom do any long distance driving with it, so I've never given a serious effort to repair it till now.
My actuator by the intake manifold is good. I repaired/replaced the several portions of bad vacuum line i found. Lastly, today i installed a new CC vacuum pump.
The light on my cruise control button lights up, but still, nothing happens when I try to engage.
What am I missing?
I followed the vacuum line from the T connector back through my firewall to the brake pedal. I don't know exactly what I'm looking for, but everything seems in order... the line isn't split or cracked. Then, from the T forward, the line is good and plugs into the black hose connector on the vacuum pump.
Am I correct in assuming that the white connector on my CC vacuum pump is supposed to vent to the atmosphere, or is there a line that's supposed to connect to it?
Do I have my lines hooked up correctly? Are there more that I don't know about?
Any help would be greatly appreciated.
Old Oct 1, 2008 | 03:42 PM
Default RE: Cruise control problem
95% of the cruise control problems on LR's is because of a vacum leak.
Check the vacum line at the brake pedal switch. I took liquid tape and gooped up all the connections on my vacum lines for the cruise control. Anywhere there is a "T" or other type of connection just goop it all the way around. Let it dry and then you should be good to go.
Evan5291
Nov 21, 2017 07:59 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
whurst79
Jun 18, 2008 06:51 PM
hanivw
Apr 23, 2008 02:02 AM
totalperformance65
Jun 9, 2006 04:58 PM
