Cruise controls...
Old Aug 7, 2012 | 10:25 AM
Externet's Avatar
Default Cruise controls...
Hi.
Do the paddle switches on the steering wheel act by pulling towards the driver, pushing or both directions ?
New owner, do not know many things, and the manual is not enlightening on it.
Old Aug 7, 2012 | 10:37 AM
oilspotLR's Avatar
Press the button on the RIGHT side of the instrument cluster.
Pull the switch towards you. You use your index and middle finger to do so.
It takes on mine about 6 seconds to engage.
Old Aug 7, 2012 | 10:53 AM
Externet's Avatar
Thanks.
Yes, the dash switch on. SIX seconds ? OK, will try.
Old Aug 7, 2012 | 11:29 AM
BrandonS's Avatar
6 Seconds?? Dang maybe my cruise does work and I just didnt' hold the switch long enough.
Old Aug 7, 2012 | 11:59 AM
G Reeves's Avatar
wow 6 seconds is way to long. Make sure the CC button is pressed on the cluster, bottom right button. You should then pull towards you the SET + button this engages the CC. You should feel a slight pull and then it set to that speed that you require. To disengage it either press the brake pedal or press the RES button.
If the system Cycles or 'hunts" the vehicle speeds up and slows down constantly then you might have a crack in or hole in one of the pastic lines.
bdorland
Sep 11, 2007 07:39 AM
etprimus
May 17, 2007 02:07 PM
WGM
Audio/Visual Electronics
Apr 14, 2007 10:32 AM
BlueDisco
Aug 22, 2006 02:01 PM
Biggles
Mar 3, 2006 06:08 PM
