Cylinder 4 Failed the Compression Test
Old Feb 19, 2021 | 04:26 PM
CollieRover's Avatar
Default Cylinder 4 Failed the Compression Test
Well, after battling my P0304 and P1319 issue, my shop tested the compression in Cylinder 4 and the compression was zero.
I am going to drive it home, park it and then put my thinking cap on. It has a ton of good parts on it, but I just don't have the time or money to spend on an entire rebuild at this point.
What have you guys done in this situation?
Old Feb 19, 2021 | 04:36 PM
Put a little oil in the cylinder and recheck compression. If it goes up we know it's a bad ring. I would be you have a valve not fully sealing up however. The oil in the cylinder will show no change if it's valve train related.
No change with the oil I would pop the valve cover off and watch as it spins over
Old Feb 19, 2021 | 05:02 PM
Best4x4's Avatar
Yep ArmyRover listed exactly what I'd do!
Old Feb 19, 2021 | 06:07 PM
Extinct's Avatar
I'll third that. A leakdown test can be used to determine where the fault is. If air is coming out of the valve cover, it is a blown ring or hole in the piston. If it is the intake, bad intake valve. Exhaust, bad exhaust valve. A good mechanic would have already done the test.
Old Feb 19, 2021 | 06:18 PM
Thanks guys. I am going to get it tonight. Will contact another mechanic to do a leak down test.
I can't damage it more by driving it can I?
Old Feb 19, 2021 | 07:55 PM
Just drove her home. Not sure what it is indicative of but the exhaust smelled terrible.
Old Feb 19, 2021 | 08:56 PM
zski128's Avatar
That’s from cat damage. You shouldn’t drive it or at least try to disable the fuel injector on #4
Old Feb 20, 2021 | 04:24 AM
I was told I couldn't do any damage. Time for a new mechanic.
Old Feb 20, 2021 | 10:48 AM
Calling about a leak down test on Monday. If it ends up being a valve, I may store the truck until I have time/inclination to fix or pull out the motor.
If it is the piston likely I will take off what parts I can and junk it. Loath to do it to a Turner Short block, but not sure I would just rather do an LS swap vs an entire rebuild.
No good choice to make really.
Old Feb 20, 2021 | 12:44 PM
zski128's Avatar
I would pull that engine and sell the turner block for sure if you are going to junk or swap. No compression like that would typically be a valve issue. It could be a piston but it would have to be some pretty bad damage. Do you have a borescope?
