cylinder 4 misfire
Old Jan 14, 2011 | 05:38 PM
chad420's Avatar
Default cylinder 4 misfire
my water pump failed and have since replaced water pump. Now since repair the truck is losing power, running rough, and have a code for cylinder four misfire. I have already done my head gasket and have magnecore 8mm wires. Anyone have any suggestions. Also getting codes po141, po140, and po1668?????
Old Jan 14, 2011 | 08:16 PM
Myllz's Avatar
3rd Gear
Check for the obvious first. Make sure all wires are seated, pull the plug and another cyl that you can compare it to. Check to see if its wet and such. Have you done coils yet?
Old Jan 14, 2011 | 08:23 PM
Myllz's Avatar
3rd Gear
Also, the P0 codes, from what I can tell by looking them up they indicate O2 sensor issues. I don't know if that is correct, maybe someone more versed in this than me can chime in.
Old Jan 14, 2011 | 08:45 PM
jafir's Avatar
P0 codes are generic powertrain codes (meaning that they should mean the same basic thing on any car)
See http://www.obd-codes.com/faq/obd2-codes-explained.php
Old Jan 15, 2011 | 07:13 AM
Bank 1 sensor 2 has failed and based on your mileage all 4 should be replaced, which, by the way, had nothing to do with your water pump.
scarrell
Nov 16, 2012 06:04 PM
louianquin
Freelander
Jun 9, 2008 03:18 AM
rover
Freelander
Apr 28, 2008 08:42 PM
xb70valkarye
Oct 23, 2007 12:50 PM
lajilana
Sep 2, 2006 10:47 AM
