Cylinder 8 misfire..Help!
04 Disco SE .....only code that is registering is for cylinder 8 misfire. Prior to that, multiple misfire codes and changed plugs and wires then ran fine for about 2 weeks.....Now, loses power at about 1500 rpm's.....engine light flashes....backfires under the hood. Took to landrover dealer to diagnose. They say may be sticky valve. $2700.00 to do valve job. Air compression good. Replaced wires, coilpack, plugs, changed oil. Other mechanic tested injectors and said were good. HELP!!!
04 Disco SE
60,000 miles
Heidi and Chad-owners
04 Disco SE
60,000 miles
