Which cylinder head is which?
Old Jan 15, 2015 | 02:43 PM
HopeItsNotAMoneyPit's Avatar
Default Which cylinder head is which?
I'm in the process of installing the cylinder heads and they appear identical, except part numbers. One is stamped HRC 2479 22 and the other is HRC 2479 21. I can't for the life of me figure out which one belongs to which bank. Help would be appreciated, thanks.
Old Jan 15, 2015 | 04:20 PM
dusty1's Avatar
same/identical
sai may differ
Old Jan 15, 2015 | 04:27 PM
Originally Posted by dusty1
same/identical
sai may differ
Thanks. I've been scouring the internet and haven't found any answers. It is strange that they are numbered differently, but whatever, it's time to put this thing back together.
Old Jan 15, 2015 | 09:24 PM
For the record, I was finally able to figure that HRC 2479 21 originally came on the left side (bank 1) and HRC 2479 22 originally came on the right side (bank 2). I finally located a wiring harness clip on the harness, near the firewall, that plugged into a metal piece that I left bolted onto the back of head HRC 2479 21.
Old Jan 15, 2015 | 10:25 PM
jafir's Avatar
Same part number for both heads, fyi. Just happens you've got two different castings.
Old Jan 15, 2015 | 11:28 PM
dusty1's Avatar
symmetrical. I mix and match between 3 sets of heads. don't even know which ones are originally paired.
scarrell
Nov 16, 2012 06:04 PM
mattyh007
Sep 22, 2009 09:56 PM
sayre05
Apr 25, 2008 09:39 PM
skyysipper
Jul 8, 2007 02:38 PM
epeteha
Mar 19, 2007 08:02 PM
