Cylinder Sleeve Slipping? ...
Old Nov 17, 2006 | 01:28 AM
MrSabie's Avatar
3rd Gear
Default Cylinder Sleeve Slipping? ...
Hi,
I hope this hasn't been discussed too much ... I did a little search and didn't find anything ...
I have a knocking/tapping in my 1996 Discovery engine ... There is no noise when I start up - but the it starts and gets louder ... And changes with the engine speed ... One suggestion was that one of the cylinder sleeves had slipped ... Any thoughts? ... If that is the problem what are the possible courses of action ...
Thanks ...
Mark
Old Nov 17, 2006 | 11:40 AM
Default RE: Cylinder Sleeve Slipping? ...
Have you overheated your engine recently?
Have you ever given your engine a really good engine flush, have you checked your oil pressure?
For starters I would say it wasn't a sleeve, not yet till other things are rulled out.
Mike
Old Nov 24, 2006 | 12:59 PM
MrSabie's Avatar
3rd Gear
Thanks Mike ... I will check with my mechanic and see what he says ...
srockrae
Sep 25, 2015 08:38 PM
sgianola
Apr 6, 2012 11:30 AM
caccia
Jan 15, 2008 06:56 PM
sdanderson
May 14, 2007 10:59 AM
