Cylinders Heads Removed, How to Move Pistons
how do i move the piston down now that i have the cylinder heads off?
i want to check the sleeve and see if there is any damage down in the block...
piston 3 is the cylinder i am trying to investigate.
Update:
Piston position before...
![](https://farm4.staticflickr.com/3841/14746934073_c9dd720781_c.jpg)
Crank Pulley:
This is what you will be rotating to raise/lower the pistons.
![](https://farm3.staticflickr.com/2932/14710735686_467fb22f85_o.jpg)
Location in Engine Bay:
![](https://farm4.staticflickr.com/3910/14547269687_4a82b262ef_b.jpg)
Bolt Size = 24 mm
![](https://farm3.staticflickr.com/2898/14733714585_654bc071a0_b.jpg)
Position of Pistons after Rotating:
![](https://farm4.staticflickr.com/3907/14547093918_859127f3bd_b.jpg)
That is how you can rotate the pistons with the engine disassembled.
Update:
Crank Pulley:
Bolt Size = 24 mm
