Which D1 to buy??
Old Nov 30, 2009 | 01:14 PM
hag1128's Avatar
Default Which D1 to buy??
94 w/ 90K Cloth no sunroof 5 speed
or 95 w/ 200K Leather 2 sunroofs 5 speed
Both are same price. Both mainly highway driven
Thanks to all who help me keep the wifes 03 running smoothly -
Old Nov 30, 2009 | 01:19 PM
Man oh man, thats a tough call, leather and sunburnt scalp or cloth and no sunburn...
Get the sunburn one.
The extra light is nice and the roof is stronger with the glass than without.
Old Nov 30, 2009 | 01:40 PM
hilltoppersx's Avatar
i dunno that leather has to be worn pretty good @ 200K..... and what is the paint and underbody rust look like? both are 5 spds! sweet find!
Old Nov 30, 2009 | 02:02 PM
hag1128's Avatar
The drivers seat leather pretty worn but rest of seats good.
no rust on 95, 94 has some surface in door frame area.
One concern was the difference in the two years distributor/ignition systems any input on that?
5 speed was a must have in my search. What is average life of the clutch?
Randy
Old Nov 30, 2009 | 03:19 PM
apcollin's Avatar
Randy
Mine has 100k and seems fine... (knock vigorously on wood)
take the sunroofed one
Old Nov 30, 2009 | 04:15 PM
XCELLER8's Avatar
that IS a tough one, sun roofs and leather........cool, lower miles......cool too.
Good luck........and then let us know maybe someone else here would like that other 5 speed !
Old Nov 30, 2009 | 05:44 PM
Randy
They both have the same ignition system.
They did not use electronic ignition until '96.
As for clutch life...depends on who drove it.
Odds are with the 200k one it has been replaced within the last 50k.
Old Nov 30, 2009 | 05:52 PM
hag1128's Avatar
I've only had 96 and newer Rovers is there a drawback to the pre '96 ignition I should inquire about?
Old Nov 30, 2009 | 05:53 PM
NiteTrain's Avatar
I like my leather and sunroofs but they're not worth 110k extra miles..go with the '94
Old Nov 30, 2009 | 06:36 PM
The ignition module will eventually need to be re-located if it has not been already.
On the 200k truck odds are it has been, there is a relocation kit at AB.
The ignition module gets hot and fails, relocate it to a cooler place and problem solved.
The other draw back is the distributor, when it goes bad, in the 150-200k range, it can be hard to find a used one and new ones are anywhere from $200 for a aftermarket one to $600 for a OEM.
When you do a tune up you will also need to replace the cap and rotor, another $50? for the set but plug wires tend to be cheaper priced.
http://www.roverparts.com/Parts/STC1857A.cfm
http://www.roverparts.com/Parts/STC1856.cfm
http://www.roverparts.com/Parts/8832KA.cfm
http://www.roverparts.com/Parts/STC1856G.cfm
http://www.roverparts.com/Parts/8832K.cfm
http://www.roverparts.com/Parts/ERR4755.cfm
I may have posted to many parts, check the description to see if it fits a DI.
