d1 starter in d2?
Old Jan 24, 2012 | 01:58 PM
tedlit's Avatar
Default d1 starter in d2?
Quick question that a forum search didn't immediately answer.. are the starters in D1's and D2's interchangeable? They *look* similar.. and the bolts line up.. but is the gearing different?
I have a '97 Discovery with a just-gone-bad starter.. and a perfectly good '00 Discovery starter sitting on the bench.... and am wondering
Old Jan 24, 2012 | 02:25 PM
dcarr1971's Avatar
Yes...it looks like this should work. BP of Utah lists the same starter for both the D1 and D2...
Land Rover Range Discovery Defender Factory Genuine OEM Aftermarket Starter
Old Jan 24, 2012 | 08:25 PM
Why would gearing matter anyway?
Old Jan 25, 2012 | 08:50 AM
kenk's Avatar
Count the teeth on the starter gear of the two starters. If they are different, nope. If so, should work.
Old Jan 25, 2012 | 09:05 AM
I agree with Kent and am pretty sure it is the same starter. Have you compared the wire connections, might make a difference.
patrolman4
Nov 6, 2023 07:48 AM
sna77
Sep 16, 2023 08:10 AM
Gimebakmybulits
Jul 14, 2014 05:57 PM
johnkbl
Apr 23, 2012 07:49 PM
hsmatharu
Defender
Aug 23, 2006 12:33 AM
