D2 ABS still working
Old Mar 10, 2024 | 01:01 AM
D2_PL's Avatar
5th Gear
Default D2 ABS still working
Hi, why does the abs relay still work after turning off the ignition? This is a problem because it drains the battery. Where to look for a fault? Replace abs control unit WABCO?
Old Mar 12, 2024 | 01:34 PM
Gripen's Avatar
I assume you're talking about the fairly quiet chirping that the ABS modulator emits? With mine, it doesn't seem to draw much power. I could leave my D2 alone for three weeks and the battery will start the engine up without issue.
Old Mar 12, 2024 | 02:21 PM
Extinct's Avatar
It can be an issue on some trucks, not sure why LR designed it that way. Not sure if it is an ECU issue or a module issue but either way it is a problem. Depending on the draw you can either rewire with another relay in series or if the draw is low enough a battery maintainer might counteract it.
Old Mar 12, 2024 | 11:27 PM
D2_PL's Avatar
5th Gear
This is the abs pump relay working.But I think it's a waste of time and work.The easiest way is to disconnect the battery when parked for a long time.My battery dies after two weeks.On the other hand, I wonder if this is not harmful to the pump, which receives a signal every second 24 hours a day.
Old Mar 13, 2024 | 04:44 AM
Extinct's Avatar
Did the battery disconnect thing for a while, then I changed to this: https://extinctmotorsports.com/solar...aintainer-kit/
Old Mar 13, 2024 | 12:01 PM
H20nSnow's Avatar
The truck can still be moving after a collision, incident, or other fault and it was deemed appropriate to make the ABS still available to the driver???? Other than that, I'm with you.
Old Mar 13, 2024 | 01:33 PM
jastutte's Avatar
nice! just put that on my list of D2 add-ons.
Edit: the link to the Blog post on your site leads to a 400 error.
Old Mar 13, 2024 | 05:56 PM
mln01's Avatar
The ticking from the modulator is completely normal. The topic comes up here from time to time, but I don't recall anyone offering a reason for why it does this.
Old Mar 13, 2024 | 06:21 PM
Extinct's Avatar
Thanks for the heads up! Fixed!
AINARS
Freelander
Aug 24, 2022 01:02 PM
zski128
Jan 5, 2021 02:38 PM
LeeH0615
Mar 5, 2012 02:27 PM
tweakrover
Sep 26, 2009 12:06 PM
drhunter
Apr 25, 2007 12:15 PM
