D2 Brake Issue.
Old Oct 11, 2018 | 07:30 AM
oaty's Avatar
Default D2 Brake Issue.
Brakes went to the floor driving to work. They will hold pressure for a second, but go to the floor. Brake reservoir was topped off. Had brakes replaced last year. Any place to check first? Brakes are not my strong point. Any help from the Land Rover Gurus would help please.
2000 D2 with 97,000 on the clock. Got last year with 83,000
Just replaced the AC compressor and window motor and regulator... Thanks to Abran and Lucky 8....you both are awesome.
Oaty
Old Oct 11, 2018 | 08:31 AM
JUKE179r's Avatar
IMHO if you had to top off your brake reservoir, then you probably have leak somewhere. Check all around your brake piping for leaks including the ABS pump and the brake caliper bleed screws.
Old Oct 11, 2018 | 08:53 AM
Best4x4's Avatar
Master Cylinder reservoir seals are famous for leaking on the OEM Master Cylinder.
Gebo
Jul 19, 2019 10:14 AM
KC_Rover
Jun 9, 2019 08:52 PM
Dubgrrl
Jan 22, 2017 06:07 PM
N.Franklin
Apr 10, 2008 10:59 PM
WINDman
May 2, 2007 12:08 PM
