D2 Died on the road.
Blinker Fluid
Or, if you need this instead:
Duralast/Crankshaft Position Sensor (SU5570) | 2003 Land Rover Discovery 8 Cylinders 6 4.6L SFI | AutoZone.com
If that does't work, you swap the CKP.
Then, if that doesn't work either, you start getting into coil and fuel pump diagnosis.
And by my recollection probly three of the "CKP" threads in the last year have actually been fuel pump relay problems.
And, for the record, the RAVE abbreviates the Crankshaft Position Sensor as CKP.
Yeah, for the record my experience has been:
Fuel Pump relay - won't start when cold
Coils - misfire when warmed up or under heavy throttle
CKP - I haven't had this problem, but what I have read is won't start when it's warm. I think dying when it's running is a less common symptom, but it does happen sometimes.
So IMO it probly is the CKP. But checking the fuel pump relay is free and takes seconds, and it may save you money, time, and frustration.
Like I said, that relay should be the first thing people check, but in this case I bet it's the CKP.
Alrighty, it's been cold as ***** outside for the past week, but with a high of 60F today I manned the F up and got under the rover.
Ripped out the old crank sensor, and then tried for an hour to get the new sensor's connector mated up to the pigtail. Wasn't very fun.
After assessing the situation I determined to work smart, not hard.
30 seconds of sawzall later:
![Name: hw2NA9V.jpg
Size: 53.5 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/56982d1683051196-d2-died-road-hw2na9v.jpg)
New sensor connected in a jiffy, flap folded back down and pinned.
Rover started right up, and ran in the driveway for 45 minutes without a hiccup.
![Name: hw2NA9V.jpg
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
