D2 Dog Guard Install Template (to cut holes in the rear upper panels)
Old Dec 2, 2020 | 07:05 PM
nashvegas's Avatar
Default D2 Dog Guard Install Template (to cut holes in the rear upper panels)
Attached is the LR template for the dog guard install in the D2. I attached a PDF and a PNG. I could not find this anywhere.
You use it on one side, then fold it over the other way for the other side (mirror image).
Sizing: When I print this from my scan, it keeps printing slightly smaller. Not sure if a PDF or Printer setting or what, but I included exact dimensions on the diagram so that you can reduce and enlarge when you print to make it the exact size. (which is important, it may require you to print a few times, trial and error)
Again: If you simply hit print on this, I think it prints out a slightly different size. You will need to resize.
Enjoy.
File Type: pdf
Old Dec 2, 2020 | 07:23 PM
nashvegas's Avatar
Here are reference pics from my install for future reference as well.
Old Dec 2, 2020 | 07:43 PM
Best4x4's Avatar
I have a perfect condition OEM D2 Dog Guard, but absolutely zero hardware for it! I had an OEM one in my D1 and I loved it!
Old Dec 2, 2020 | 11:37 PM
greisinb's Avatar
Phenomenal- at the risk of wanting too much is there a way to figure out where to make a cutout for the rearward set of holes? They would be a good mounting point for a ceiling rack I want to fab up, something like this:
Old Dec 3, 2020 | 08:31 AM
nashvegas's Avatar
Possibly. No template exists I'm aware of.
The absolute easiest thing would be to get side panels off a 7 seater, as they have a grab handle in that location that attaches front and rear.
Barring that, an idea: Without removing the interior trim, it wouldn't be too tough also to use the template to do the front cutout (as I did in these pics) and then measure distance to the rear holes and do a similar sized rectangular cutout. This would then be a very secure mount for such a ceiling shelf. Probably best to measure in a salvage yard or buy those grab handles on ebay and measure (as my panels are back in!).
Old Dec 3, 2020 | 08:55 AM
Red5's Avatar
That makes a very clean install. I don't have dogs, but would this also work for wife/kids?
Old Dec 3, 2020 | 11:17 AM
greisinb's Avatar
I think I'm going to make the front cutouts with your template and then estimate the distance to the rear holes. I have some drafting software that could make it pretty straight forward with the help of your photos. If I'm off by a little it won't be a big deal as my disco is far from mint.
Old Dec 3, 2020 | 11:53 AM
specops1526's Avatar
Couldn't you just cut the front hole, take measurements from there to the rear holes and mark the panel for the rear cuts?
Old Dec 3, 2020 | 11:55 AM
Also, I think years ago I called AB and they sent me the instructions along with the template. I think they had it in PDF format and it prints true to size. Not sure if they still have it available though but worth a try.
Old Dec 3, 2020 | 01:59 PM
greisinb's Avatar
Well, I'll be darned. A close inspection reveals I already have that hardware installed from a PO, I had no idea that's what it was for!
