D2 locking up on full right turn?? Anyone know what could be the problem
Old Jul 15, 2019 | 04:55 PM
Gareth1988's Avatar
Default D2 locking up on full right turn?? Anyone know what could be the problem
Hi there is there anyone that can help. I’ve just mot’d my disco after being stood up for two months.
Now ive got a problem with the truck locking up when driving and turning right I’ve changed the front diff but still no luck
Old Jul 15, 2019 | 07:27 PM
mln01's Avatar
Hello and welcome to the forum. Please help us help you. What do you mean by "locking up"?
Old Jul 16, 2019 | 12:37 AM
Gareth1988's Avatar
Hi by locking up I mean when driving and turning right on full lock it’s like putting the brakes on but I’m not touching the pedal
Old Jul 16, 2019 | 02:02 AM
JUKE179r's Avatar
How big are your tires?
Do you have a lift?
Old Jul 16, 2019 | 02:19 AM
Gareth1988's Avatar
Hi the truck is standard with 18 inch wheels
Old Jul 16, 2019 | 03:24 PM
Llamasayswhat's Avatar
What year is your car? Do you have a center lock?
It sounds like differential/transfer case bind with the transfer case locked
Old Jul 16, 2019 | 03:36 PM
Gareth1988's Avatar
Hi It’s a 2003 Es with no centre lock
Old Jul 16, 2019 | 08:23 PM
CollieRover's Avatar
Intermediate steering shaft u joints look in good knick?
Old Jul 17, 2019 | 07:23 AM
Gareth1988's Avatar
Looks ok
its like putting the brakes on so don’t think is anything to do with the steering but thanks anyway
Old Jul 17, 2019 | 10:29 AM
Richard Gallant's Avatar
  • Jack the front end up, put some jack stands underneath
  • Unlock the steering wheel so you can turn the tires
  • Move the tire by hand a little bit then spin
  • Keep doing this until you feel resistance
  • Now get a big flashlight and inspect everything for binding left and right side
  • If you can not see anything obvious pull the tires look for rubbing or damage to the wheel wells and brakes or brake lines
  • Also do the hub wheel/bearing test - I do not have link handy but you can google it
I know this sounds trite but it is not rocket science, you can eliminate simple stuff like the transmission and transfer case because it is only when you turn right. It has to be tire/brake/steering related so that mean getting under there and seeing what is up
