D2 Power-Steering Pump
I'm searching info on these pumps & coming up empty.
Original manufacturer
Parts breakdown
I'm interested in the output bearing. I haven't found ANY material on the web in regard to it, nor is it supplied in any rebuild kits.
Parts breakdown
If there's a Napa around you...
Sometimes I have success there, take the part you want to replace, and see if they have something on the shelf.
My Napa has a huge selection of bearings and many times I can find the same one or one with the same dimensions.
chubbs878, your buddy shanechevelle has a good suggestion.
Remove bearing, inspect for PN, purchase new bearing and install it.
That's great. Thanks! Can you point me to your ref? Maybe I will find something else that catches my attention
if you have the bearing dimensions this will get you a part number
Product tables Right hand side you can search by size
Chubbs, that's a very common bearing size. Any reputable bearing supplier will have them in stock. A 42 15 13 is used in many applications so no real probs.
right; I have been getting them @ a bearing supplier down the street
