D2 ran out of gas. Can't keep running. Please help
Old Nov 15, 2019 | 12:20 PM
Bodeanjt's Avatar
Default D2 ran out of gas. Can't keep running. Please help
So my 1999 D2 ran out of fuel (v8 has engine) I put 5 gallons in it but it would keep shutting off after a few minutes running. Then I would have to put start fluid in it to get it to crank. After sitting for a while it will crank up no issue but only run about 10 minutes and shut off again. I replaced the fuel pump with a new one and still getting the same results. What else could be causing this issue? Please help?
Old Nov 15, 2019 | 01:00 PM
Richard Gallant's Avatar
Try another 5 gallons, at 5 gallons you are pretty much at the add fuel light.
If it still fails check the fuel pump relay under the hood
Old Nov 15, 2019 | 03:26 PM
Bodeanjt's Avatar
I filled the tank up and still have the issue but I will check the relay. Thanks for the help.
Old Nov 15, 2019 | 04:00 PM
Red5's Avatar
When it stops, does it stumble and sputter then die? Or does it just stop like you turned off the ignition?
Old Nov 15, 2019 | 06:05 PM
Extinct's Avatar
Might want to check the fuel pressure using the test kit at Oreilly
Old Nov 15, 2019 | 06:25 PM
Friday Night Disco's Avatar
You may have over heated the fuel pump and cause damage to the pump
Old Nov 15, 2019 | 06:59 PM
Bodeanjt's Avatar
Relay was good
Old Nov 15, 2019 | 07:02 PM
Bodeanjt's Avatar
Just stops like you shut off the engine
Old Nov 15, 2019 | 07:03 PM
Bodeanjt's Avatar
I replaced the pump with a new one and get the same result as the old one
Old Nov 15, 2019 | 09:30 PM
I apologize as I read that now in original post. Could you have pulled some gunk that is now clogging injection. Is there any codes present or pending?
