D2 whining
D2 whining
Okay, maybe i am being paranoid but my Landy whines quite a bit when accelerating and even while just constantly on the throttle. It seems to go up in pitch with RPMS, so something tells me it may be the tranny but i suppose other things spin with RPM speed. It sounds like a bad power steering pump but it doesn't happen with the turn on the wheel, just the RPM Speed.
Thanks for any help!
You can take a screw driver and put the handle to your ear and move it around and touch metal things on the engine. You are probably looking at idler pulleys, water pump, or alternator. Do it with the engine running and be careful not to touch the fan.
You could also remove your belt and spin each pulley. Check for any play or roughness.
alright jason if it does it in park then it has to be somthing on the front of the engine pulley ect. take the belt off and turn all the pulleys and check for play/wobble.also the alternators tend to whine a little on these trucks take a screwdriver and with the engine running put it up to the case of alternator carefully put your ear to the butt of the driver and see if you hear your whine
