D2 whining
Old Mar 26, 2010 | 07:56 PM
Jason_B's Avatar
Default D2 whining
Okay, maybe i am being paranoid but my Landy whines quite a bit when accelerating and even while just constantly on the throttle. It seems to go up in pitch with RPMS, so something tells me it may be the tranny but i suppose other things spin with RPM speed. It sounds like a bad power steering pump but it doesn't happen with the turn on the wheel, just the RPM Speed.
Thanks for any help!
Old Mar 26, 2010 | 08:00 PM
Jason_B's Avatar
BTW no ACE, and SAI
Old Mar 26, 2010 | 09:15 PM
willrok13's Avatar
Does it make the sound while accelerating from 0-10 mph and then stop? And as speed builds the whining elevates pitch?
Old Mar 27, 2010 | 02:06 PM
ROVERTECH15's Avatar
jason you need to check where the noise is coming from we cant help you if dont give us somthing to work with is it coming from the motor or the driveline?
Old Mar 27, 2010 | 02:53 PM
okdiscoguy's Avatar
You can take a screw driver and put the handle to your ear and move it around and touch metal things on the engine. You are probably looking at idler pulleys, water pump, or alternator. Do it with the engine running and be careful not to touch the fan.
You could also remove your belt and spin each pulley. Check for any play or roughness.
Old Mar 29, 2010 | 10:28 PM
Jason_B's Avatar
It is defiantly coming from underneath the vehicle, right at the rear of the oil pan.
Old Mar 30, 2010 | 07:59 AM
hilltoppersx's Avatar
have you rebuilt or replaced your drive shaft with one with greasable u joints? when was the last time you serviced your tranny and transfer case?
Old Mar 30, 2010 | 08:58 AM
okdiscoguy's Avatar
Does it do it when you are in park and rev the engine?
Old Mar 30, 2010 | 01:52 PM
Jason_B's Avatar
Yes it does do it in park,
I have serviced the tranny about 2000 miles ago, with a fluid and filter change. I have not yet done the transfer case, i have the parts to rebuild the driveshaft, and will be doing it this weekend.
Old Mar 30, 2010 | 03:46 PM
alright jason if it does it in park then it has to be somthing on the front of the engine pulley ect. take the belt off and turn all the pulleys and check for play/wobble.also the alternators tend to whine a little on these trucks take a screwdriver and with the engine running put it up to the case of alternator carefully put your ear to the butt of the driver and see if you hear your whine
