DAMS - Discovery Acronym Management System
Our forum language is changing with the time. In the future, we may not use any words in a post, as it can be written with all acronyms.
Example: 03 D2 HSE 71k w/ ABS-TC- HDC 3 Amigo’s SOS For standard web acronyms see the “Internet Acronym Dictionary” http://www.gaarde.org/acronyms/?lookup=A The following is an acronym list to share with others who are learning that to “walk the walk” of the Discovery, and they also need to “talk the talk” of the Forum. We are making up new acronyms all the time, so be prepared to keep adding to the list. Note: please let me know of any errors or omissions DAMS - Discovery Acronym Management System A ABS - Anti-lock Braking System ACE - Active Cornering Enhancement (D2) A/C - Air Conditioning AEL - Advanced Evaporative Loss System AIC - Additional injector controller Amigo - 3 Amigo’s warning lights ABS-TC-HDC (D2) ARB - Manufacturers of 4x4 accessories AT - Automatic Transmission AWD - All wheel Drive B B4 - Before C CDL - Center Differential Lock (D1 94-98, and D2 04) CO - Carbon Monoxide (smog test) D D1 - Discovery I (US 1994-1999) (1989-1999) D2 - Discovery II (1999.5-2004) Diff - Differential E EBD - (D2) Electronic Brake force Distribution ECU - Engine Control Unit, Gems (D1) 96-99, Bosh (D2) 99.5-04 EGR - Exhaust Gas Recirculation (not used on the Discovery) F FAQ - Frequently Asked Question G GEMS - Engine Control Unit, General Engine Management System (D1 96-99) H HC - Hydro carbon (smog test) HDC - Hill Decent Control (D2) HG - Head Gasket HID - High intensity discharge (xenon) lights HSE - Discovery model (D2) 03, 04 I IAC - Idle Air Control sensor IM - Intake Manifold IMO - In my opinion J JK - Just Kidding K K&N - Brand of air filter L LR - Land Rover LSE - Discovery model LOL - Laugh out loud M MAF - Mass Air Filter sensor mm - millimeters MPG - Miles per gallon MPH - Miles per hour M&S - Manual and Sport Mode – automatic transmission MTBF - Mean time between failures (reliability) N NG - No Good O o2 - Oxygen as oxygen sensor OBD-II - On Board Diagnostic (engine fault codes) OEM - Original Equipment Manufacturer OME - Brand 4x4 accessories – Old Man Emu P PAS - Power Steering Pump PM - Personal Message PO - Previous Owner Q QED - Quite Easily Done R RR - Range Rover RRC - Range Rover Classic (1970-1996) Rave CD - shop manual download http://www.landroverresource.com/ S SAI - Secondary air injection (D2) 02, 03, 04 SES - Service Engine Soon warning light SD - Discovery model SE - Discovery model SE7 - Seven passenger SE SLS - Self Leveling Suspension (D2) SVS - Shuttle Valve Switch ABS-TC-HDC T T-case - Transfer Case TC - Traction Control TPS - Throttle Position Sensor U U - You UR - You’re V VC - Valve Cover VSS - Vehicle Speed Sensor W WD40 - Brand Name penetrating oil X X fer - transfer case XYZ - Switch on side of automatic transmission to tell the controller the selected gear Y Y - Why Z zzz - that’s it for tonight |
bump. IMHO GPFATNTTF (good post for all newbies to the forum)
Wrong, HSE is a model designation on all land rovers including freelander, RRS, RR, Discovery models. There are base models now with different models. For example Discovery 4 has XG, XS, HSE Freelander two has S, XG, XS, HSE Range Rover Sport has SE, HSE, SC also HSE with LUX package Range Rover, Vogue, Vogue SE, SC, Autobiography editions. depending on country some are a package and some are more personal. And don;t forget all the special Editions XD RR,D1 Camel Trophy defender, freelander, DI, RRC Rhino RR P38 Holland and Holland RR P38 AND new RR 2010 Holland and Holland edition Linley RR p38 Safari D2 kalahari Defender South Africa West Minister RR and D2 Versius Orange RRS 06 G4 defenders, Freelanders, Freelander2, D2,D3, RR, RRS Autobiography Range Rovers and Sports Fire and Ice Defenders Trek vehicles since 1997 and most of your acronyms for systems and module names arent even close with what we use. |
Originally Posted by Rovin4life
(Post 180308)
and most of your acronyms for systems and module names arent even close with what we use. Rovin, good job, sometimes we forget that what we're saying doesnt even make sense to everyone. I said CDL to a mechanic once and he didn't have a clue i was talking about center diff lock... |
Imagine a 2010 RR HSE with all the bells and whistles and all of those bells and whistles have at least two or three modules with their own acronyms.
I have a list of my training manuals that list something along the lines of fifty acronyms for modules. Thats not including the regular Periodic tables listed including NOX, CO, MO, CH, Oh and we have wiring color schemes which differ per vehicle. Older ones use a different system then the newer ones. There is alot there trust me. |
(Post 180321)
I have a list of my training manuals that list something along the lines of fifty acronyms for modules. Thats not including the regular Periodic tables listed including NOX, CO, MO, CH, Oh and we have wiring color schemes which differ per vehicle. Older ones use a different system then the newer ones. There is alot there trust me. I think it was more of a informative thing rather than a technical thing. But i'll let eaglewing answer that. |
This is the Land Rover Discovery Forum for Discovery I and Discovery II owners and comments and lists should be focused for those people who want to know about their Discovery trucks (Not LR3 or RR or Defender). This is why I made the list of Discovery items that kept coming up in our forum. Newby’s questions of what is this were sometimes not answered. In the spirit of openness I felt this small but focused list was important to the understanding of our conversations in this forum. I am not a trained Land Rover mechanic and I am always humbled by the knowledge that others have. What makes this form great are the people and their sharing of knowledge. We solve problems together.
Love it! This is a great idea...probably would make for a great sticky in the "New Members" area so first-timers have a reference to all the Disco lingo.
................IMHO, of course;) |
ha to most CDL is commercial drivers license! I am sure we have quite a few others that are rover specific that would mean something else to other people. I thought it was a great post. I also remember a time when I had to ask what TPS meant, so maybe it will be beneficial to someone.
Thank you guys for the kind words, I feel better about this now.
I have a 98 DI which is electronic simple compared to the DII’s with many more acronyms. This list started so that I could understand what was being talked about on the forum for both DI and DII’s. It was a good learning exercise. If it worked for me so I decided to share it with the forum. |
| All times are GMT -5. The time now is 04:57 AM. |
