dash buttons
I "assume" you have a Disco 1, So the switch your on about is the Cruise Control enable switch. The "symbol" on it is the same as the road signs in the UK, its a picture of a motorway / highway with a bridge over it, Ie most likely when you would use cruise control
It would be the same symbolas the 3rd switch down here on my Disco 2
that is the cruise control button, Disco I Disco II, both the same. When i first got mine, I thought it kinda looked like a surfboard!
Use it whenever you can and it will helps with the mpg's!!
There is one under the steering wheel, and one under the hood.
To get to the one under the steering wheel turn the two screws ONE time and it will unlock the cover. The fuse box under the hood is on the left hand under a rectagle cover, there is a picture of a Fuse and I beleive it says fuses also.
TRIARII
Jan 21, 2015 05:37 PM
battsup
Jul 15, 2005 10:29 PM
