Dash Curl
Old Jun 14, 2021 | 10:05 AM
wrightb8289's Avatar
5th Gear
Default Dash Curl
Looking for information/parts to replace my upper dash on my disco. It’s warped away from the plastic radio surrounds and would rather just replace the whole top of it to correct this issue. Seems nearly impossible to obtain a dash these days
Old Jun 14, 2021 | 11:34 AM
Richard Gallant's Avatar
@wrightb8289 A picture would help
Old Jun 14, 2021 | 11:57 AM
5th Gear
Old Jun 14, 2021 | 01:31 PM
jastutte's Avatar
Originally Posted by wrightb8289
mine's doing the same thing and i've been looking for a good solution that doesn't require a new dash. no luck so far, but i'll post up if i find something.
Old Jun 14, 2021 | 06:56 PM
kjogel's Avatar
4wd High
Same here - front is solved via dash hold down kit but not how to remedy this bad boy.
Old Jun 14, 2021 | 07:00 PM
5th Gear
Anybody know where I can source a new upper dash. It’s driving me crazy
Old Jun 15, 2021 | 08:06 AM
TimInNova's Avatar
First read through this thread and look for the word "Aquaseal".
https://landroverforums.com/forum/di...t-80287/page3/
Good luck and please learn how to use the advanced search of this forum. There is so much knowledge here that almost any issue you come across already has a solution.
Old Jun 15, 2021 | 09:51 AM
dswilly's Avatar
I had decent success in gluing mine down along the windshield. I used e6000 adhesive and wedged sticks between the headliner and dash. For the curl you have there you might try splinting it from below with a piece of flat stock steel if there is room. Glue it up and hold it in place with weight, see what you get.
Old Jun 15, 2021 | 01:59 PM
Tony Luna's Avatar
Replacing the dash isn't as hard a job as one would think. I did mine a couple of years ago following the instructions in the Rave manual - not bad at all. I also picked up another nice spare dash from a local Pick and Pull for $60 in case I end up having to doit again later down the road...
Old Jun 15, 2021 | 02:47 PM
redwhitekat's Avatar
was there not someone selling a disco here that had the dash bolt down strap down mod ?
