Dash Lighting
RE: Dash Lighting
It's easy. you have to remove the stereo to get to the screws behind there, remove the clock, remove the pocket above the ashtray and the ashtray, remove the switch panel for the cruise and fog lights.. Once all that is removed you will have access to all the screws that hold the center trim piece in. Ok, easy isn't really the right word but it's not that difficult. I have to do the same thing as soon as I remember where I put the removal keys for my aftermarket radio,
RE: Dash Lighting
I was thinking of the switches for recirculation and a/c. Sorry about that. Tom is correct, pop all 3 round ***** and the **** on the fan speed switch. behind 2 of the round ***** are screws that hold the climate control panel on. Remove those and the front panel comes right off exposing the single bulb for the climate control. The switches for recirc and a/c have to be disconnected from the back before they can be pulled out and the bulbs replaced.
RE: Dash Lighting
Thanks,that was easy. The ***** pop right off. I wasn't sure they did and didn't want to chance breaking any of the plastic as it gets brittle after 11 years in this Texas heat. I had the clock out this weekend changing that bulb aling with the shifter lights in the console.
bcolins
02-22-2014 08:50 AM
bulldozer32
05-24-2010 10:30 AM
