Dashboard buttons...What are they???
I can't seem to find this info, so can someone please explain to me what all the buttons around the gauge cluster do, and around the clock etc.. Thanks! One looks like a rear fog switch which I tried and it works. I have a switch for the front but I have no front foglights?? Also,can anyone run a carfax??
RE: Dashboard buttons...What are they???
Rear wiper is on the right top. Are you talking about the front fog light switch? That is the one next to the master cruise control switch. It is very common to remove the front fogs when they go bad, It improves your approach angle and saves you having to fix them.
They will not work with the high beams on.
The rear fogs only work with the lights on.
