dealer ?
Please be seated. Take a deep breath. This may hurt.
If you had a overheating incident, from the original defective head gaskets, you may have also caused a cylinder sleeve to drop from its normal position. This can be repaired, but it is a good deal of money (much more than head gaskets) and dealers usually want to install a new engine instead.
However, since they did the new head gasket work, you should stop doing any other work on it and let them examine it to see what they will fix under their warranty of the head gasket.
The slipped liner is the result of overheating, not the cause of it.
Now on the good side, you could have a number of other problems that are no where near as serious, they just decided to pop up at the same time.
So the dealer should evaluate what is going on, if there are additional items not covered on the original estimate you have somewhat of a negotiating position, you most likely won't get them for free, but you may get a reduced price on them since they already kissed you for the head gaskets.
By the way, what did they charge for the head gaskets job?
dealer
they charged 2300 + 567 for ignition wires now they want ten grand to fix it they strippped a bolt going in the first time they did the gasket then they drovit it over heated they replaced the therm and it overheated again. they then took it apart again and are saying its my problem after they siad it was all inspected and good before they put on the first head gasket now thier looking for a trade in for me? is this my fault if they messed up? what do you think they want ten grand to fix it now
Mike, Please post your findings after you call him so the next "sucker" can reference this thread.
