Decent Cheap LEDs
Just installed five 4" LEDs I bought off amazon and thought I'd provide some feedback on them. I installed two 30* spot lights on the center of the rack and two 60* floods on the out edges, along with one 60* flood on the rear of the rack. They cost about $25 a piece, so I wasn't expecting too much out of them, but I don't have the budget right now to spring for name brand lights at $150+ a piece. They are extremely solid feeling, have good mounting hardware, and put out a good amount of light. Way too bright to be legal to run on the street. All 5 of them seem to have more or less the same beam pattern so I think the spot/flood distinction is just something they made up. I left the rear light on accidentally for about 16 hours when camping last weekend and the battery showed no signs of being low, so they're good work lights. I'll eventually swap them all out for Rigids but for now they're a pretty solid substitution.
Here's the link:
http://www.amazon.com/gp/aw/d/B007ZGBLNW
Here's the link:
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
I'm using 3 relays, each of those has battery+ (With in-line 30amp fuse), load (to lights), ground, and switch (to inside the cab). The switches have the line coming from the relay, and a hot line coming from the positive terminal on the battery. I didn't want to deal with running a ground to the switch so the little LEDs don't light up, but other than that it all works well.
