Decent Cheap LEDs
Old Jan 28, 2014 | 06:13 PM
etsZac's Avatar
Default Decent Cheap LEDs
Just installed five 4" LEDs I bought off amazon and thought I'd provide some feedback on them. I installed two 30* spot lights on the center of the rack and two 60* floods on the out edges, along with one 60* flood on the rear of the rack. They cost about $25 a piece, so I wasn't expecting too much out of them, but I don't have the budget right now to spring for name brand lights at $150+ a piece. They are extremely solid feeling, have good mounting hardware, and put out a good amount of light. Way too bright to be legal to run on the street. All 5 of them seem to have more or less the same beam pattern so I think the spot/flood distinction is just something they made up. I left the rear light on accidentally for about 16 hours when camping last weekend and the battery showed no signs of being low, so they're good work lights. I'll eventually swap them all out for Rigids but for now they're a pretty solid substitution.
Here's the link:
http://www.amazon.com/gp/aw/d/B007ZGBLNW
Attached Thumbnails Decent Cheap LEDs-image-1631789996.jpg   Decent Cheap LEDs-image-3325644947.jpg   Decent Cheap LEDs-image-3651080514.jpg
Old Jan 28, 2014 | 07:41 PM
dusty1's Avatar
thank you for the review and link. if they get the job done, i'd be happy. I have busted and lost rigids...I go cheap now. $30- $50 a light is my new budget. I will buy cheap, even if it has a plastic guard in the shape of a chinese symbol, as long as it does its job.
Old Jan 29, 2014 | 11:32 AM
SuperSport's Avatar
They say cast Aluminum. Maybe scrap Aluminum from Fukushima, but hey, the price is not bad. And, as a bonus, they glow when turned off!
Old Jan 29, 2014 | 11:52 AM
dusty1's Avatar
^ that would be a cool feature. I could get one of those hipster biohazard stickers
Old Jan 29, 2014 | 12:01 PM
SuperSport's Avatar
That's just like YOU Texans! Always trying to nuke people... yeah, I went there...
Old Jan 29, 2014 | 12:26 PM
dusty1's Avatar
Yeee haw, succeed!!!
Old Jan 29, 2014 | 01:56 PM
mattmo78's Avatar
So, where did you run the wiring to hook up the power and the switches?
Old Jan 29, 2014 | 03:20 PM
etsZac's Avatar
I'm using 3 relays, each of those has battery+ (With in-line 30amp fuse), load (to lights), ground, and switch (to inside the cab). The switches have the line coming from the relay, and a hot line coming from the positive terminal on the battery. I didn't want to deal with running a ground to the switch so the little LEDs don't light up, but other than that it all works well.
Old Jan 29, 2014 | 06:01 PM
dr. mordo's Avatar
Very interesting. I've been thinking about replacing the factory spot lights on my truck because they suck.
These are so cheap I'm tempted.
Thanks for the info!
Old Jan 29, 2014 | 06:04 PM
SuperSport's Avatar
Ditto. I've got factory Yellows up front, and they really don't help much, even in fog. Very dim.
donduck
Mar 9, 2015 05:31 PM
dusty1
Aug 21, 2014 01:49 AM
TRIARII
Jul 20, 2014 10:38 AM
EricTyrrell
Mar 12, 2012 11:44 PM
RenoHuskerDu
Nov 9, 2011 01:56 PM
