Defective TF shocks only about 6-8k miles
Old Jul 3, 2017 | 06:41 PM
KingKoopa's Avatar
Originally Posted by Best4x4
Bilstein needs to offer the 5100 for D2's! I love those shocks. I've had several sets of TF shocks and I had good results with them and their bushings.
I bet you can find a 5100 that will fit on the rear of you just cross reference the length you need. The front would be a different story.
I just put 4600's on a 3/4 ton ford and I'm fairly certain the rear shocks would have been a direct fit on my disco and might have fit on the front of it had the pin in the bottom
Old Jul 3, 2017 | 10:38 PM
OffroadFrance's Avatar
Munro shocks used to be good and economical but I don't know whether they are any good these days.
Please don't tell me TF are rubbish, I've got them on my truck
TF118's and 119's also a steering damper.
Old Jul 4, 2017 | 12:46 PM
ZGPhoto's Avatar
All I can say is, sorry! Ever since my poor experiences with Terrafirma shocks, I've been preaching the same thing. Supposedly they've improved quite a bit from when I ran them, but I switched to Fox and haven't looked back.
Old Jul 4, 2017 | 01:07 PM
KingKoopa's Avatar
What does your suspension setup consist of? My concern with the Fox shocks and a 2" lift is that the body is too long and will inhibit max compression.
Old Jul 4, 2017 | 10:00 PM
Luckyjayb's Avatar
Great Basin rovers can get you the blisteins. They swap out the bushing on all of them and put in poly bushings that are made to fit the d2.
Old Jul 5, 2017 | 08:07 AM
ZGPhoto's Avatar
RTE 3" springs, Fox performance series 11" remotes
Compression isn't an issue, nor is extension
Old Jul 10, 2017 | 04:27 PM
me6067's Avatar
Just wanted to give everyone an update... TF isn't replacing these as they are out of warranty but the great people at Lucky8 gave me a slight discount on a new set. I am happy with this as a resolution as every little bit helps.
Old Jul 10, 2017 | 04:48 PM
KingKoopa's Avatar
You get terrafirma again or upgrade to something else?
Old Jul 10, 2017 | 06:21 PM
me6067's Avatar
Given my new engine problems I'm sure you've now read my budget is a tad limited and TF will be going back in.
Old Jul 10, 2017 | 06:36 PM
Big Jim Swade's Avatar
My OME's on my Disco are holding up nicely. I wish I could say the same about my Rancho RS9000's on my Nissan Frontier. I had to replace the fronts after 25k miles and the rears are about done at 35k.
