Delayed Dash Lights
I have the same issue with my 2000 Disco. When I turn on the headlights though, I get no dash lights and my rear driving lights will not come on either until 3-5 minutes have passed. My issue...and yours, may be related to the headlight switch on the console. Try turning the lights on and off 3 or 4 times. That seems to get mine working. I suppose a new switch is in order at this point.
Wow....glad I posted this question....it happened again this morning and I jumped out to check if I had tails lights....I did not.....I have driven it a bunch of times at night and didn't realize this....I did switch the lights off and on 4 or 5 times and the all the lights came on...do you think it I need to replace the headlight stalk or could there be a relay issue somewhere......thanks again!...
First thing you need to do is check all of the bulb sockets for corrosion, clean them and use dielectric grease and then I would replace the bulbs, even though they are "good", $5 and you can KNOW they are good.
Let us know what you find, but I do not think it is in the switch, I think it is in the tail lights.
