Dented front diff cover
Old Apr 4, 2011 | 05:08 PM
Bundu's Avatar
Banned
Default Dented front diff cover
It happened, I dented the front cover on my front diff. Must get diff guards...
It is not dented enough to touch the crown, I pulled the diff out to check, there is no shiny spot on the inside so the crown did not rub.
I thought I would bang it out with a hammer, think again. **** I lay into that thing but all I achieved was a headache and sore arms.
What next? Put it back together and forget about it?
Old Apr 4, 2011 | 06:19 PM
jafir's Avatar
do you have a plasma cutter and a welder? ;-)
Differentials & Other Land Rover Parts | Diff Repair Pan Front W/Hole
Old Apr 4, 2011 | 07:02 PM
antichrist's Avatar
if the crown wheel isn't rubbing I wouldn't worry about it.
Lot of option for diff protection. It's not uncommon for the bolt on to get knocked off.
For the ultimate in protection replace the tin cover with a weld on pipe cap.
Old Apr 4, 2011 | 07:04 PM
Swap it with the one from the rear and forget about it, outta sight outta mind.
Old Apr 4, 2011 | 07:30 PM
texmbr's Avatar
If it isn't rubbing..put it back on and wear it proudly.
Old Apr 4, 2011 | 08:29 PM
Bundu's Avatar
Banned
Battle scars...
I buttoned it all back up and will look at some protection.
@antchrist I've been looking all over for a weld on pipe cap, they seem to be scarce as hell. I was thinking if I can find one I will cut the old one off and weld that on, that 1/4" pipe cap should take some beating. I'll most probably get a shop to do the welding, my welding looks like turkey crap
Old Apr 4, 2011 | 08:30 PM
Wolf's Avatar
No rub, no worry. If it bothers you so much that you have to replace contact Bill at Rovertym. He has a wide selection of HD parts.
Old Apr 4, 2011 | 08:36 PM
antichrist's Avatar
A pipe cap to fit would have to bought at an industrial pipe supply house.
Old Apr 4, 2011 | 09:49 PM
dcarr1971's Avatar
A couple guys that I wheel with warned me about the diffs, so after good tires, the diff guards and recovery points were my #1 priorities.
One of my other buddies wasn't as lucky as you were...
Picasa Web Albums - Dave C - 2010-10-04
Old Apr 4, 2011 | 10:27 PM
NiteTrain's Avatar
diff cover? diffs with 3rd member don't have a cover..you mean the diff housing? they look thick..what did you hit?
