Device/Info needed for parts
Old Aug 22, 2014 | 12:26 AM
Esfour's Avatar
Default advice/Info needed for parts
2000 Disco II
Looking into replacing my cats due to sounding like there is coins moving around in there. Would like to know what cats do you guys/gals recommend?
Pulled the headliner off and seems like the front sunroof motor is missing screws/bolts. Already looked at the RAV and didn't find screw/bolt info. Can anyone please tell me what bolts/screws I need for me to properly secure it back in place?
TIA
Old Aug 22, 2014 | 07:52 AM
Jared9220's Avatar
I installed a magnaflow y-pipe and I have to say that I am not a fan of the 2 piece design. They make the 2 cats in 2 different pieces and you connect the two with a collar that you tighten down. No matter how I tighten it I still have an small exhaust leak at that point.
A trick to help find exhaust leaks is to have a helper hold a towel over the exhaust for a few seconds while you feel around for the air leaking out.
I think if I were to do it again I would buy either the davico or bosal y-pipe and save $100-$200. Don't forget to buy the two new y-pipe to manifold gaskets.
Old Aug 25, 2014 | 01:13 AM
Esfour's Avatar
Thank you for the info. Rather than doing that is it possible to just have the cats cut off and have new highflow cats welded on? If so is there a certain one to go with or certain cells? There seems to be a lot options when I look online but want to get the correct cats.
I am also looking to replace my plugs and I started looking at Bosch platinum plus 4 as disco Mike recommended but there seems to be different models in that, what is correct part number for this?
TIA
imike1007
Jul 21, 2010 08:31 PM
Disco Mike
Mar 18, 2009 02:50 PM
Disco Mike
ROAMING WITH FRIENDS
Oct 25, 2008 08:43 PM
DV57
Jul 16, 2007 10:53 AM
wildhorses
Oct 20, 2005 01:13 PM
