Dex-cool FLUSH down the sewer drain?
I am defiantly nature conscience being an avid hunter and fisherman, but this weekend I will change my dex-cool to a non dex-cool aluminum safe coolant (and change the thermostat as well) and was wondering if it was ok to let the coolant FLUSH go down the sewer drain being that dex-cool is biodegradable.
I will capture the old dex-cool coolant as it comes out of my lower radiator hose into my oil catcher pan (the local dump said they will take it), but I'm sure I will not have enough room in the oil catcher to do a couple of hose water flushes as well to make sure all of the old coolant is out.
Is it wrong to let the hose water flush go down the sewer? It is biodegradable isn't it? My gut reaction says not too, but I wanted get another opinion.
on
hopefully you mean flush down the toilet or sink, and not down the storm drain.
i imagine the treatment works would not encourage you to do this, but depending on the plant, i imagine the removal efficiency is pretty high.
rv's winterize their toilets and sinks with antifreeze...
Second, why the hell would you flush your coolant down the toilet, I have known people who should have been shot for less stupid things. Great to add to our drinking water.
Flush your system and do as you are supposed to and take it to an auto parts store for disposal.
First why are you wanting to switch to an unproven coolant for your truck that are prone to head gasket issues already.
I'm switching AWAY from Dex-cool and putting in PEAK Global™ LifeTime™ 50/50 Prediluted Antifreeze & Coolant (proven by Spike and others on the thread and is aluminum safe). And I only meant to flush the empty radiator "hose flush water" down the storm drain, not the actual Dex-cool (which I will capture in my oil catcher). I just assumed that I will probably go through 10 or more gallons on the flush with the "hose water" and my oil catcher will not hold that much.
Since Dex-cool is biodegradable, I'm trying to figure out the harm of letting the "hose flush water" ONLY go down the storm drain? The dex-cool I catch in my oil catcher will go to the county dump. NO auto parts stores in my area will take old coolant, only oil. Not Advanced Auto, not Schucks, not Parts Plus.
Isn't this why dex-cool was put in the truck in the first place, because it was environmentally friendly? According to my research, Propylene Glycol based (OAT) anti-freeze/coolants: "It is biodegradable and requires no special disposal costs or procedures in most areas. Above all, its low toxicity presents no threat to children, pets or wildlife."
So which is it, biodegradable or not? It can't be both.
