DI ABS Questions
DI ABS Questions
Ok so I am trying to understand the ABS on a DI..
First of all..
The light comes on every time I start the Truck, then goes out after I start to drive.. NORMAL??
Second...
It seems to me that the ABS dosent work very well.. I would go so far as to say that "IT IS DANGEROUS"!!!
Today, for example.. I was leaving the jobsight their were cars on one side of the road, I was going down hill approaching an intersection. A woman comes around the corner WAY to fast.. The cars were on her side of the road. I put on the brakes and moved all the way to the right. My right front tire barely left the road into the grass, and locked up, the ABS comes on, It makes a whining sound through the speakers, the pedal goes soft and I am at the mercy of the ABS.. I still had 3 wheels on solid pavement, yet now the entire brake system is held hostage by ONE WHEEL!!! Is this how it is supposed to work?? Good thing it wasnt a child in the road!!
First of all..
Second...
RE: DI ABS Questions
Ok, I think the lights mean that there have been faults in the past that are stored in the computer, but when you start off, it shuts off because the faults are no longer present. Mine has been messed up from day 1, so I can't tell you what normal is.
Sounds like your ABS worked properly, with the exception of it going soft. Did your pedal just push to the floor when it happened?
the lights are normal, they come on and when the vehicle reaches 7 mph they go out, its to check your wheel speed sensors. and the noise doesnt come through the speakers, its the abs unit under the hood that it actuating the brake lines. however yes, the system is not that great, when it activates, you better be ready to stand on that pedal or you wont stop. abs activating causes the car to take longer to stop, but it allows you to still be able to control the car.
Yes the ABS on a DI sucks A$$.
The ABS light comes on when you start the truck and then shuts off after you reach 5-7MPH.
Here is how you fix your ABS.
Open the hood, open the under hood fuse box, remove the ABS fuse, close under hood fuse box, close hood.
You will never have ABS issues again.
The ABS fuse has nothing to do with the check engine light.
I pulled the fuse under the hood because it is the same as throwing a circuit breaker in the breaker box, it removes all power to that circuit.
Removing the fuse under the dash is like turning off a light switch, it only cuts power to the light.
If you pull the fuse under the hood there is no need to pull the fuse under the dash.
ORIGINAL: Spike555
Thats exactly what I thought would solve it..
I've always had the problem of my ABS coming on whenever I came to just a regular stop. Uphill, downhill, left, right, didn't matter. The pedal would start pumping and I'd have to basically stand up in my seat on the pedal to stop in enough time. The light has been on since I've owned the car for the past four years, and I just got used to it and ignored it. I've recently pulled all of my ABS fuses from under the dash and under the hood, and my ABS light is still on in the dash display. I haven't had any other ABS problems since pulling the fuses, but I don't know why the light hasn't gone off in the dash. At least I'm not worried about accidentally not stopping quick enough because of some stupid faulty ABS
