DI Fan Clutch Removal.....
Old Dec 23, 2009 | 08:48 AM
BajaXJ92's Avatar
Default DI Fan Clutch Removal.....
I've got an adjustable wrench on the fan clutch bolt, I'm just not sure what to pry against to keep the entire fan and clutch from spinning because there isn't enough tension on the serpentine belt. I can't seem to get a wrench on the idler bolt either. Does anybody have any tricks to keep it from spinning?
Thanks!
Old Dec 23, 2009 | 09:14 AM
lipadj46's Avatar
This is what I have used on a DII many times:
https://landroverforums.com/forum/sh...hlight=viscous
Old Dec 23, 2009 | 09:44 AM
BajaXJ92's Avatar
Your DII is a bit different than mine from the looks of the pics!
Old Dec 23, 2009 | 09:55 AM
lipadj46's Avatar
You should be able to do something similar though, see if there are any bolts or holes in the pulley you can connect a simple spanner to.
Old Dec 23, 2009 | 10:01 AM
BajaXJ92's Avatar
Should be easier for a few people now!
Old Dec 23, 2009 | 10:03 AM
BajaXJ92's Avatar
BTW - I'm tapping mine to the left, however I'm reading on a few different older posts here that the threads on the viscous fan bolt are reversed. I looked at the new one carefully and it appears I'm loosening it the correct way, can anyone confirm this?
Old Dec 23, 2009 | 10:08 AM
lipadj46's Avatar
You need a Rave CD (in is normal threaded):
NOTE: Nut securing viscous unit to water
pump has a right hand thread. Release by
turning anti-clockwise when viewed from
front of viscous unit.
Scharfire
Jul 6, 2021 02:59 PM
jafir
Feb 10, 2017 11:08 AM
Thatdudeuno1
May 1, 2012 05:10 PM
dino109
Jan 1, 2012 03:38 PM
rover1978
Sep 26, 2009 09:05 PM
