DI t-case shifter on my D2
Old Feb 23, 2009 | 12:43 PM
jycsalas's Avatar
Default DI t-case shifter on my D2
I recently added the bits and pieces (CDL HOUSING) to my non-locking t-case. I removed my stock hi/lo cable shifter assembly and am waiting for the DI shifter from roverlandparts.com to arrive and want to know if anyone has pics of this linkage. (either installed or not)
I have no idea how to install it nor what it really looks like other than the image on roverlandparts.com, RAVE, and parts catalog. I'm sure I'll be able to figure it out once it arrives but until then.... i have you guys...
Thanks
Old Feb 23, 2009 | 01:49 PM
NW_rockhound's Avatar
Hope this is what you are looking for.... http://www.lrrforums.com/showthread.php?t=3248
This article was very helpfull when I put mine in, took longer that I thought.
Old Feb 23, 2009 | 03:32 PM
jycsalas's Avatar
Holy S*!t
Maybe I should save and get the 04 assembly lol...
Is there anything else you did while installing this setup? or did you follow these instructions step by step?
Old Feb 23, 2009 | 07:55 PM
Give yourself 4-6 hrs and a 6-pack of good brew to complete this. A couple pointers:
1) Completely clean and lubricate the linkage when you get it. Don't just hold it in one hand and hose it down with WD-40. I mean, disassemble and clean, then grease the socket where the linkage and shifter meet. This is most important, otherwise you'll be pulling it back out when you find it is not moving properly.
2) When the directions tell you to leave the old cable linkage in the truck and zip-tie it to the harnesses on top of the transfer case: This is way, way easier than removing the bracket holding it in. Believe me, the last thing I wanted to do was leave it there. NEVERMIND, just noticed you removed this already. Now I'm jealous!
3) Understand the fact you will need to make some adjusments to the linkage.
It works fine after all said and done. I could not justify the $200 difference in price for the 04 model after realizing this one does the job and I only use it about once a month.
Old Feb 24, 2009 | 08:13 AM
jycsalas's Avatar
Well I actually got the cable removed last week. It WAS a pain in the @$$. Leaving it like the write-up suggests was not an option. I am worried i guess that even after I clean it up and grease and lube the linkage, it will not work smoothly.... but i will try it.
Question: My original cable setup has the shift interlock that would not allow HI to go into LO without the transmission being in neutral... does the DI linkage have something similar?
Old Feb 24, 2009 | 09:17 AM
The linkage has nothing to do with that features, the switch on the tranny and the solenoid on the t/case control the lock out.
Old Feb 24, 2009 | 11:28 AM
jycsalas's Avatar
I am confused then... what is that pin that moves in and out underneath the hi/lo shifter bracket...
this is mine
Old Feb 24, 2009 | 11:54 AM
good question. Mine did not have that. Is your truck a diesel? Mine is a gas v-8. Hope someone can answer this, and I hope your new (used) linkage has that lockout.
Old Feb 24, 2009 | 12:21 PM
jycsalas's Avatar
I wish mine was a diesel...
I don't believe my t-case has the interlock switch on the casing. According to RAVE, for the 03 models it was moved from the t-case and up to the shifter assembly... so I guess i just need to be careful to not accidentally engage in low while not in neutral..
I think i answered my own question... lol
Attached Thumbnails DI t-case shifter on my D2-03-up-t-case-description.jpg   DI t-case shifter on my D2-03-up-t-case.jpg
jycsalas
Jul 21, 2009 02:32 PM
jycsalas
Mar 23, 2009 01:21 PM
Discover' Carolina
Mar 8, 2009 06:54 PM
rcshauger
Oct 3, 2008 05:36 PM
texmanmoore
May 5, 2008 07:52 PM
