Diagnostic Tools Recomendations
Old Oct 25, 2013 | 03:01 PM
jafir's Avatar
Originally Posted by CaptainCulp
I just got the Autocom CDP+ as well. It seems to be the cheapest option to get diagnostic data, run tests, clear codes/amigos, reset Transmission Adaptations, bleed brakes, etc. It also has a live mode you can use when you're driving if you buy a microSD card. The software installation is a B*%&# but once you get it done (requires PC, not Mac) it's fairly robust for $100. It also works with tons of other makes and models.
Can you actually configure the BCU with it? Such as turning on and off things like heated windscreen and fog lights? What about key fob programming?
If it will do all of that kind of stuff, it is a STEAL.
Old Oct 25, 2013 | 05:01 PM
SuperSport's Avatar
On my wife's VW I can, but I have not checked on the Disco yet. I will do that as soon as possible and get back to you.
Old Oct 29, 2013 | 07:13 PM
Enrique5's Avatar
Default Thank You
Thank you all for the information you posted!
Enrique
Old Oct 29, 2013 | 08:06 PM
Enrique5's Avatar
Default CPD Product
I found this information on the CPD product:
Discovery 2 [98-04] MY2004
[Generic OBD]
Supporting EOBD/OBDII
Ecu marked "Eobd"
MT/AT
Y
16 pin OBD (J1962)
18K16
Mems 3 (80 pine ecu)
1,8
Diagnose on PIN 7
MT/AT
Y
Y
Y
Y
16 pin OBD (J1962)
18K16
1,8
Diagnose on PIN 8
MT/AT
Y
Y
Y
Y
16 pin OBD (J1962)
[Generic OBD]
Ecu marked "Eobd"
MT/AT
Y
16 pin OBD (J1962)
10PA
TD5
2,5
MT/AT
Y
Y
Y
16 pin OBD (J1962)
15P
TD5
2,5
MT/AT
Y
Y
Y
16 pin OBD (J1962)
ABS
WABCO
MT/AT
Y
Y
Y
Y
16 pin OBD (J1962)
Gearbox
Bosch GS 8.87
AT
Y
Y
Y
16 pin OBD (J1962)
Airbag
TRW-GENIV
Y
Y
16 pin OBD (J1962)
Body
BCU & transmission
MT/AT
Y
Y
16 pin OBD (J1962)
Body
Gauges
MT/AT
Y
Y
16 pin OBD (J1962)
Body
Heated window
MT/AT
Y
Y
16 pin OBD (J1962)
Body
External lighting
MT/AT
Y
Y
16 pin OBD (J1962)
Body
Security
MT/AT
Y
Y
16 pin OBD (J1962)
Body
Warning lights & sounders
MT/AT
Y
Y
16 pin OBD (J1962)
Body
Wash and wipers
MT/AT
Y
Y
16 pin OBD (J1962)
Body
Windows & sunroof
MT/AT
Y
Y
16 pin OBD (J1962)
It didn't paste well but its page 282 on this link:
https://autocom.se/uploads/file/AppT...DPPro_Full.pdf
Old Oct 30, 2013 | 01:53 AM
SuperSport's Avatar
Unfortunately, no, it does not. It reads and resets most codes on most components. It can also run most switches, bulbs, and valves, but it won't do keys or coding.
Old Dec 21, 2013 | 03:04 PM
Boxcars's Avatar
What about "Service Required" reset after the DIY oil change.
Old Dec 21, 2013 | 03:23 PM
jafir's Avatar
Disco 2 doesn't have such a message.
My hawkeye and my nanocom can reset the service message on LR3.
Old Jun 10, 2014 | 05:28 PM
galahad's Avatar
I have LR DII, 2004, TD5, manual
I borrowed from a friend nanocom and unfortunately I have a problem,
I can change various settings in the car, but nanocom can not connect to the engine.
I tried to connect another diagnostics computer to my LR engine and also failed to connect.
I checked the socket under the steering wheel and it looks good.
I don't know where to look for the cause of this problem?
Where to find fault? Maybe some cable under the hood is broken?
Do you have any idea what I should check and how to fix it?
Old Jun 10, 2014 | 05:49 PM
acg's Avatar
acg
Does your friend use his Nanocom for the same model, i.e., D2 TD5? The Nanocoms come with different module apps for D2 V8 Motronic, Diesel, etc.
Old Jun 11, 2014 | 03:07 AM
galahad's Avatar
He has D2, TD5, 1998, automat
and nanocom works with its engine,
but also other diagnostic computer can not connect with my D2 engine,
so I guess my engine is something wrong
