Diagnostic Tools Recomendations
Old Jun 11, 2014 | 11:31 AM
  #21
jafir's Avatar
Have you checked for blown fuses?
How about oil in the ecu connector under the hood. (I have no idea if this would cause the problem you're having but it's a common issue for the td5 injector harness to get oil in it.)
Old Jun 11, 2014 | 06:38 PM
  #22
OffroadFrance's Avatar
I use an Autel MaxiDiag MD702 as I wanted to use it on other vehicles but it has limited functions on the LR. The only problems are Autel are franchised, their website downloading updates is rubbish and they are a PITA to deal with once you've paid over your money. The problem with Nanocom is they are only LR specific and although very good, probably the best for the D2, they are limited to the LR range. Whereas the Hawkeye is pretty comprehensive for LR's and can be used on other vehicles if you purchase additional codes which like all things, aren't cheap. It's a real quandary what to buy for the best alround use for the D2 and other vehicles without paying a small fortune for technology that'll be out of date in a year or two. Like many, the Autel reads and clears codes and reads live data but you cannot access or tweek anything or operate any LR function remotely as it is really just a passive code reader with live data reading ability. Would I buy one again? I very much doubt it having had some of the problems with this one and the Autel lack of response or interest in sorting out their website issues.
Old Jun 12, 2014 | 04:38 AM
  #23
galahad's Avatar
I cleaned the oil red plug from the ECU and still nothing.
I do not know which fuses to check, but I'll check them all.
Maybe one is blown ...
To be sure to ask what the socket is in D2? OBD-II?
Maybe I'll buy another cable and the diagnostic program for the PC ...
Old Jun 12, 2014 | 05:34 AM
  #24
Originally Posted by galahad
He has D2, TD5, 1998, automat
and nanocom works with its engine,
but also other diagnostic computer can not connect with my D2 engine,
so I guess my engine is something wrong
Hi be aware as many tools are vehicle/type/zone specific and require additional vehicle codes to be purchased before they work. Typically, a reader for a TD5 in Europe may not read a TD5 in the US. I rune a TD5 export model which was originally designated for south America and had trouble with European code readers. I believe it's another money spinner for them.
Old Jun 13, 2014 | 03:43 PM
  #25
galahad's Avatar
Perhaps you're right.
Today I borrowed from a friend the USB cable from the plug to the OBD2, will install on the laptop program IDS Land Rover Jaguar and free time I'll try to get to the engine.
amonem
Jan 25, 2014 11:40 AM
jafir
Jan 11, 2014 11:28 AM
Kalev
Nov 14, 2013 08:36 PM
DonRW2007
Apr 1, 2011 10:43 AM
jason0595
Aug 27, 2009 10:26 AM
