Diamond Plate Rear Side Window
Old Apr 28, 2013 | 05:42 PM
ruining's Avatar
Default Diamond Plate Rear Side Window
Got some trail damage today.
I saw a picture of a Disco, (can't remember if it was a 1 or 2) online that had diamond plate instead of this rear side window. Is there someone that pre-cuts to the shape of the window or a kit somewhere, or would I need to just cut it myself?
Would that be the best, least expensive way to go about it?
Attached Thumbnails Diamond Plate Rear Side Window-942859_599687860042461_2099102366_n.jpg
Old Apr 28, 2013 | 06:07 PM
coors's Avatar
Damn. What happened?
Old Apr 28, 2013 | 07:49 PM
Those trees will jump out and bite you.
I would guess that you will need to do it yourself
Old Apr 28, 2013 | 08:38 PM
ruining's Avatar
Trees, indeed. My 'spotter' told me that I could make it, no problem. The roots from the tree on the left kicked me up just a half an inch higher than he expected and broke out the window.
Once I was passed that, the taillight guard caught onto the tree and yanked it out. The light will go back in, no problem. I'm thinking I'll just be putting diamond plate in place of both rear windows.
The think I'm the most worried about is the power steering fluid leak that came from nowhere. I had to run it without for about 20 minutes on the trail and now has a permanent whine. I'll be looking into that next.
Old Apr 28, 2013 | 08:56 PM
MuddMouth's Avatar
Man that sux... id have to bitch slap that spotter though!!!!
Easy fix though... just template it with card board no problem.
Power steering is either tank ... which fails often or lines... obviously. If its anything like my Bimmer theirs seals where the lines go into the pump and unit... try there. Those seals usually go first.
BMW when they got involved with LR transferred all their problem areas in engineering. Seems all the same issues with cooling and leaks.... they run great when not on jack stands
Old Apr 28, 2013 | 09:23 PM
You'll be needing a new radio antenna, Rover ones are in the glass.
Old Apr 29, 2013 | 09:43 AM
SuperSport's Avatar
slanginsanjuan
Dec 30, 2011 02:00 PM
slanginsanjuan
Nov 18, 2011 06:33 AM
joefresso
May 28, 2011 10:42 PM
hilltoppersx
Jan 21, 2010 09:39 AM
