Dicovery II running on 4 cylinders
Could this be a timing problem?
Since I don't have (and can't find) a manual for this car, I have no idea what I'm really looking at, but I can tell a few things from simple observation.
It runs on the front 4 cylinders (1234)
It backfires through the intake, sometimes enough to blow the plastic intake tube off the manifold
It has fire in all 8 holes
It runs poorly on 4 cylinders - meaning that it takes a while to rev up, and then can loose power even while pumping the accelerator.
Could this be a timing problem? I don't know which sensor runs the timing and fuel injectors.
I thought maybe the camshaft broke between 4 and 5, but was told that it was impossible to run the motor at that point.
I really don't want to tow it to the Land Rover dealer to pay them $$$$$$$ for a sensor or some tiny part.
Anybody know of a manual for this model? Haines and Chilton evidently don't have one.
Do a search for the "rave" manual, it is THE repair manual for our trucks, it is the same one the dealer uses.
The crank sensor controls spark.
The cam sensor controls injector timing BUT it cat/wont fire the injectors if it is not getting a signal from the crank sensor.
The crank sensor is VERY common to fail on a DII, in fact it is a guarantee to fail part.
