Did I Buy the wrong O2 sensor?
Old Sep 10, 2013 | 08:55 AM
Jason428sc's Avatar
Default Did I Buy the wrong O2 sensor?
I have a 2003 Discovery with 87000 miles on it and it keeps throwing 2 codes. The P0134 and P0150. I have recently changed the front O2 sensors with two I bought off ebay for about $30 a piece (see link below). Before I changed them, It was throwing codes P0130 and P0150. I think it may have something to do with the vibration I'm having that starts at about 25 mph. It doesn't vibrate while cruising at 55mph, just when I give it some gas. Anyone have any ideas? Cheap O2 sensors?
Land Rover Range Rover Discovery Upstream Front O2 02 Oxygen Sensor | eBay
Old Sep 10, 2013 | 09:02 AM
Can you say "JUNK", you can't cut corners when buying 02's.
Do you have a scanner that can read the output from the 2 sensors, are you still getting any codes since your replaced them?
Did you clean all the oil from the connections?
Old Sep 10, 2013 | 09:33 AM
Jason428sc's Avatar
Mike, I did clean the oil from the connectors and put die electric grease in them when I installed them. I'm still getting P0134 & P0150. My scanner does not read the output from the O2's.
Which O2 sensors should I buy? Or should I invest in a new scanner?
Thanks,
Jason
Old Sep 10, 2013 | 10:19 AM
br0keit's Avatar
You could have spent $20 more and got legit Bosch ones from a much more reputable company (amazon)
Bosch 15175 Oxygen Sensor, OE Type Fitment : Amazon.com : Automotive Bosch 15175 Oxygen Sensor, OE Type Fitment : Amazon.com : Automotive
Old Sep 10, 2013 | 11:18 AM
drowssap's Avatar
there is someone in the for sale section that has a pair from amazon that they don't need, he's asking almost the same but I'm sure you could talk him down to an agreeable price.
Old Sep 10, 2013 | 03:42 PM
AwannaD2's Avatar
I just did the Walker o2's. Got them on ebay for Miami British for 130 shipped. Atlantic British sells the same ones, but the dont tell you theyre Walker.
But if you get a better price on the Bosch ones go that route
Old Sep 11, 2013 | 04:25 AM
jfall's Avatar
You can only put on Bosch O2 sensors.
Those ones you bought on eBay - open a case and return them.
They are Junk as Mike said.
Old Sep 11, 2013 | 06:31 AM
Jason428sc's Avatar
Thanks guys. I will be ordering new ones.
KlamathMatt
Apr 17, 2020 05:27 AM
Rover Rebel
Jan 31, 2015 09:22 AM
br0keit
Jul 8, 2012 03:53 PM
bertl
Freelander
Dec 13, 2009 01:01 PM
luxury1
16
Dec 28, 2008 02:07 PM
