Did option B. Now left with 1 lonely Amigo
I did the option B fix. Hill descent and TC lights are gone, but the ABS light remains. My scan tool does not show any error codes. What gives? (Scan tool has ability to read ABS codes and had a shuttle valve electrical failure code which lead me to the option B fix)
Like I’ve mentioned before, if you clear the ABS faults & then start up the D2 you will have just the ABS light on. You must move the D2 (normally 100ft or so) then the ABS Sensors will send info to the SLABS Unit & once it see’s activity from the 4 ABS wheel sensors the light will go out.
