Three amigo no fixo
Old Dec 24, 2011 | 10:26 PM
rholtporsche's Avatar
Default Three amigo no fixo
I have the three amio virus. I tried the fix that seemed so promising in the forum, but the fix failed. I have tested the abs modulator, as well as my connections, and everything is legit. Where else, other than the modulator could the amigos spring from. I'm pulling my hair out on this one.
Gracias
Old Dec 24, 2011 | 11:13 PM
borchera's Avatar
The members will need your ABS codes before any analysis can begin. There are so many areas on your truck being able to set the three amigos. Either the Hawkeye OBDII Diagnostics tool or an ABS Amigo can read codes for the ABS system.
Both are great tools for trouble shooting the ABS system. I had the ABS Amigo prior to purchasing the Hawkeye.
Our three amigos turn on immediately after we replaced the shuttle valve seals. We ended up replacing the shuttle valve switch and the ABS solenoid pack. Three months now without those lights (knock on wood).
2003 Discovery with high miles service complete and a 124 K miles.
Old Dec 25, 2011 | 12:07 AM
Thanks a lot. I will buy the amigo code reader pronto. I have no idea where to get one, or where to plug in. Does it plug i where the other code reader plugs in? Thanks again!
Old Dec 25, 2011 | 12:31 AM
boris_gti's Avatar
I am dealing with same issue right now.
http://www.rswsolutions.com/index.ph...d=56&Itemid=55
This seems to be the answer.And like the other person mentioned, you need to scan and read the codes before you start making repairs. Could be something as simple as your speed sensor. In which case you did the wrong repair.
Old Dec 25, 2011 | 09:26 AM
RSWsoultions.com
kallgrer
Jan 14, 2010 08:54 AM
silver06hemic
Jan 2, 2009 03:51 PM
Dino76
Feb 12, 2008 03:03 PM
ajh
Oct 12, 2007 09:02 AM
lrblack12
Aug 22, 2007 02:35 PM
