Did the shuttle valve fix. Amigos gone?
I spent the evening with an ABS amigo and some quality time under the hood to tackle my intermittent 3 Amigos.
The only code stored in SLABS was for the shuttle valve problem despite having the intermittent Amigos for the past year.
Anyway, I did jycsalas' fix and it started up with no lamps.
I'm assuming that there's a self check at startup and any ABS issue will make itself known should there be something terribly wrong.
Since I'm clean after a test drive, is it safe to assume that I didn't muck up the ABS system?
Asking because I wanted to get jycsalas' ABS Amigo back to him ASAP.
meltdowndave,
mildy incompetent mek-a-nik.
meltdowndave,
Just curious which fix you did? Did you do the one where you remove the shuttle valve assembly and cut the plastic housing and resolder the pin or did you do the one where you just remove the switch and rewire it to avoid the circuit board.
I'm planning on doing the latter one in the next week or so.
BTW, you don't necessarily have to remove the 8 allen bolts connecting the two halves of the ABS modulator unless you just want to look inside.
Just loosen the modulator's 3 retainging nuts and remove the rubber mounts. Lift it up and remove the 3 allen screws from the bottom. It took me 45 minutes to get them all out and then back together.
Everyone else, I took it out for a test run in the mud and snow this AM. The conditions on the old logging roads were perfect for this sort of test.
Anyway, the brakes pulsed as they should during a high speed stop in the slick, the TC worked as the tires searched for grip going up hills and the HDC engaged going down some gnarly hills that probably should have been passed over.
Three hard runs and not the first lil' buddy.
Thanks to jycsalas for the ABS Amigo and an incredibly easy to follow write up.
on
I rewired it.
Under the option C and the now updated step #38 =)
I rewired it.
Just loosen the modulator's 3 retainging nuts and remove the rubber mounts. Lift it up and remove the 3 allen screws from the bottom. It took me 45 minutes to get them all out and then back together........
Did you do bleeding after this, before you take it to test drive?
on
But if you look at steps #25 - 29 all you need to do is loosen the brake pipes from the bulkhead, remove the rubber mounts and support the unit high enough to remove the screws for the SVS cover plate.
LET ME KNOW WHAT I NEED TO CLARIFY IN THE WRITE-UP SO OTHERS DON'T GET CONFUSED...
