Did the three Amigos repair and still getting the HDC light
And you did not replace the shuttle valve or seals did you?
You need to buy the kit or at least the seals from Falcon Works along with a new shuttle valve, then follow Josh's directions on a complete rebuild.
When I performed my shuttle valve repair, there was no brake fluid on my switches either, but the switches tested bad with a multimeter. I replaced the switch, the seals, and did the wiring modification for good measure.
Did you test the switch, or just splice the wiring?
Not sure why you have to come across like a dick Mike.
I did test the switches and they were in spec, but if that what I got to do then I replace the switches.
Man I got to be honest, you obviousy were a service rep at Land Rover Cause a lot of those guys are arrogant A holes too.
