Diff between Ttrack and Detroit?
Other then the price, can anyone tell me what the differences are between these two?
Lucky8 Llc. - Take the road less traveled...
the truetrac is a limited slip diff the detroit is a full locker.
read this
4x4 & Torque answers - JeepForum.com
read this
so the ttrack is just a built up replacement for stock config, while the detroit will add the option to lock the front and rear diffs for left right?
good article, but where does the disco fit since thats jeep?
heres what i gather, please correct me where im wrong for the disco system:
front and rear diffs are limited slip, so you can still lose side to side traction, and also front to rear unless you lock the differential. with trutrack, it would remain the same situation, but with different gear ratios and stronger components... while with the detriot it would be the same storey, but benefit from the fact that you could lock the front and rear diffs in the same fashion as you can the xfer case now?
This is it from what I understand talking to Disco Mike.
Detroit locker rear -best option. It allows different wheel speeds for on road driving
True Track front. One wheel revolution slip and it locks up the front to full lock.
More reliable than ARB air compressor driven as it is all mechanical. No air lines to break or compressor to malfunction.
You will need to upgrade the rear axles to 24 spline to support the locker. I am not sure about the front.
