Is this the Diff Lock?
Old Jul 8, 2013 | 02:34 PM
caymandrew's Avatar
Default Is this the Diff Lock?
Guys, I just looked on top of my 2001 Transfer Case and it appears I DO have the diff lock? This is it right?
Old Jul 8, 2013 | 02:43 PM
ZGPhoto's Avatar
Yessir!
Old Jul 8, 2013 | 02:50 PM
caymandrew's Avatar
SWEET! I've read the threads about adding a D1 tcase to a D2 etc, etc. I guess all I need is the shifter and cable?
Old Jul 8, 2013 | 02:53 PM
bballjames's Avatar
And lots of RTV.
Old Jul 8, 2013 | 02:55 PM
ZGPhoto's Avatar
And plenty of time if you've never taken the tunnel cover out before.
Old Jul 8, 2013 | 02:59 PM
caymandrew's Avatar
OK - this might be a fun project then, turns to the left of the truck to engage?
Old Jul 8, 2013 | 03:05 PM
bballjames's Avatar
It turns clockwise
Old Jul 8, 2013 | 03:11 PM
So, are you going with a D1 or 04 shifter set up?
Old Jul 8, 2013 | 05:00 PM
caymandrew's Avatar
I guess neither. I just built a level for about $5 and it works pretty well. It's under the truck but extends out past the frame so I can reach it while standing next to the truck, instead of having to climb under it. I only have about an hour into this and I'll post a video in a little bit.
Old Jul 8, 2013 | 05:09 PM
bballjames's Avatar
That will work. However, as the t-case must be in neutral, make sure you're truck doesn't roll away as you get out to lock the diff! And it could be messy if you are in the mud.
