Diff Lock Problem?
Old Feb 10, 2009 | 06:47 PM
daniep's Avatar
Default Diff Lock Problem?
On my 03 disco I can't get my diff to lock. The gear shifter thing won't move to the left. Is there a trick to it or does something need lubed? Thanks
Old Feb 10, 2009 | 06:48 PM
AK Rover's Avatar
Default RE: Diff Lock Problem?
03 models do not have diff lock from the factory. That may be your problem.
Old Feb 10, 2009 | 06:52 PM
daniep's Avatar
In my owners manual it says it does?
Old Feb 10, 2009 | 06:55 PM
02's and 03's don't. Do you see your diagram above your shifter, you only have high and low, probably have a manual from another year.
Mike
Old Feb 10, 2009 | 06:58 PM
daniep's Avatar
there's a sticker for low and high range then to the right there is another sticker for the diff lock
Old Feb 10, 2009 | 07:01 PM
Jupiter Rover's Avatar
ORIGINAL: Disco Mike
Mike
The 2003 manuals Actually talks about the difflock being an option. I think Nick (urban panzer), or p76rangie from LRO said it was an option overseas. Who knows.
Old Feb 10, 2009 | 07:02 PM
daniep's Avatar
I found some more info here http://www.4x4community.co.za/forum/...ad.php?t=18198
Old Feb 10, 2009 | 07:45 PM
okdiscoguy's Avatar
IF you have it and you can't move it, get under the truck and spray some penetrating lube up around the linkage. Gently move it back and forth, trying to work it in. I take it you aren't in the states...
Is there a diagram on the shifter handle?
Old Feb 10, 2009 | 07:48 PM
Just because the manual says its there does not mean that it actually is.
One manual covers all trim levels and options and such.
Old Feb 10, 2009 | 07:59 PM
llPANCHOll's Avatar
Photo??
