diff lock question
If I engage differential lock (dash light on, driver differently)
then jack up one wheel (front drivers side if it matters) how much should the wheel move?
Mine will move about 2/15ths of a turn back and forth...
shouldn't it be totally locked and not move at all, I still gotta test the back wheels
thanks
thanks
The transfer case is locked, not the differentials. The wheel will move a little as their is play between the pinion and ring gear. If the T-case were unlocked the wheel would spin freely.
Cheers,
Pete
Cheers,
Pete
I could be wrong. The Rover diff may not allow it turn to unless both wheels (same axle) are off the ground. I think you are okay as far as your Rover is concerned. I know that one wheel can spin freely if the TC is not working and the T-case is not locked. What year Rover do you have?
Cheers,
Pete
Cheers,
Pete
ORIGINAL: tomfraser
yeah... i mean when it is totally disengaged (light off, drives normal)
my wheel still turns only about 1/4 turn, not freely...
thanks for replies
thanks for replies
