diff lock question
Old Dec 10, 2008 | 04:58 PM
tomfraser's Avatar
Default diff lock question
If I engage differential lock (dash light on, driver differently)
then jack up one wheel (front drivers side if it matters) how much should the wheel move?
Mine will move about 2/15ths of a turn back and forth...
shouldn't it be totally locked and not move at all, I still gotta test the back wheels
thanks
Old Dec 10, 2008 | 05:55 PM
Switzer's Avatar
Default RE: diff lock question
The transfer case is locked, not the differentials. The wheel will move a little as their is play between the pinion and ring gear. If the T-case were unlocked the wheel would spin freely.
Cheers,
Pete
Old Dec 10, 2008 | 06:01 PM
tomfraser's Avatar
so would I have an issue if the wheel does not spin freely with center diff unlocked?
Old Dec 10, 2008 | 06:05 PM
Switzer's Avatar
You would need to roll the car for a bit before the t-case is actually unlocked. Mine usually takes several feet of rolling before the light will go out.
Cheers,
Pete
Old Dec 10, 2008 | 06:17 PM
tomfraser's Avatar
yeah... i mean when it is totally disengaged (light off, drives normal)
my wheel still turns only about 1/4 turn, not freely...
thanks for replies
Old Dec 10, 2008 | 06:21 PM
Switzer's Avatar
I could be wrong. The Rover diff may not allow it turn to unless both wheels (same axle) are off the ground. I think you are okay as far as your Rover is concerned. I know that one wheel can spin freely if the TC is not working and the T-case is not locked. What year Rover do you have?
Cheers,
Pete
Old Dec 10, 2008 | 06:48 PM
tomfraser's Avatar
95 disco v8 automatic
Old Dec 10, 2008 | 08:15 PM
I my humble opinion you are over thinking all of this, you got your CDL to work, all is good, enjoy the truck.
Old Dec 10, 2008 | 08:21 PM
tomfraser's Avatar
will do
got my new lever coming friday
gonna have my car put together by saturday morning
gonna "enjoy the truck" sunday (hopefully there will be some snow)
Old Dec 10, 2008 | 10:43 PM
NW_rockhound's Avatar
ORIGINAL: tomfraser
thanks for replies
Did you try this with the transmission in neutral and not in park? My bet is you had one wheel off the ground, the transfer case unlocked and the transmission in park. The driveshaft still will not move due to the transmission park prawl holding the drivetrain from moving. Oh, the same goes when the parking brake is on too. Block the wheels on a flat surface when you try this.
