differential fluid change
one more question, it looks like my t/case has a small leak. Does Lucas or anyone make a additive to help with this? If I put some of the Lucas trannie additive in would that help? Thanks everyone, I know I just went on a question spree...
when i was resealing the transfer case (see sticky thread for information) i recall finding some threads here about using a product called white shepherd to help seal the transfer case. it wasn't very pricey, about 10 bucks, so i gave it a shot and zero leaking so far. maybe you could give that a try?
I changed the front diff oil on my 93 defender 90 and oil drain plug seems to be leaking now. I know it is a tapered thread so did not expect it to leak. Any tips ? Should I have used plumbers tape ? I would have expected land rover to use a rubber O-ring or something more than just relying on the thread.
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
